1 - 10 of 10 Posts
:censored: fail!
Average of about 2.3 when I needed to meet the newer 1.5 limit by 8 registration days:furious:
I made sure to give it a good Italian tune-up before the test, and literally drove it straight into the test bay, so I know it was fully warm and as clean as I could get it. I have used redex additive in the past, but not recently, so I've dumped some of that in the tank. I thought about shoving some through over the weekend, but was worried that I might loosen up some crap that would then cause an issue today.
The air filter was changed a few hundred miles ago, so I know that's OK. I've also run some foam cleaner (I can't remember the make) through the inlet manifold a while ago and that stopped a smoke on initial start issue.
I've read online that removing the air filter for the test can make quite a difference. Is this true as I'd have thought the MAF would just trigger a different mix? Or is that the point?
Any other suggestions?
Are you 100% sure you don't have a slight air leak? Look on top of your inlet manifold for any black oily residue, this usually means you are getting a bit of a boost leak past the swirl flap bushes, this effectively richens the mixture.
Is your DPF fitted & working?
I'll check for that, cheers.
I was under the impression that the DPF filters out particles that aren't tested for?
Smoke is soot, DPF should normally catch it.. Mostly the 159s I see failing MOT emissions tests are the ones with DPFs replaced with a straight pipe or gutted internally.
I'll attack it with the pressure washer.
I then may/may not have to refit it:paranoid:
Shove a load of Redex in, but still shouldn't make that much smoke
find a local supplier of Biodiesel (there are an increasing number around, you might have to google it or ask around)
stick a 50% mix in (50% bio, 50% supermarket (Morrisons))
I used to run 100% Bio in my last 1.9JTDm with no issues and no emissions (every MOT I had came up with 0% when tested)
Axe.
1 - 10 of 10 Posts
