Hello there!
So I want to get some Diagnostic Software and a cable so I can connect my laptop to my 2001 147 to primarily switch off -
(yes; you've guessed it; only one guess needed)- Airbag Warning Light.
:smash:
So I have these two discs already and I've used the 'ePER' one to look up parts and try and figure out how to access things etc;
However I've not really explored the 'eLEARN' Technical Assistance Manual CD ROM at all and I'm wondering in fact does it contain/ or is it indeed the diagnostic program?
As in do I just need to get the required Cable and I'm away?!
Please please any advice on the simplest affordable way to sort this!
(Other than paying someone else to do it as I've tried that and soldering airbag connectors and still I think the best thing to do is get software so I can turn it off myself (not only to pass MOT but because I'm pretty sure back along on the forum someone said the airbags don't deploy if the Airbag Warning Light is on) or get an Airbag ECU from a 2004 onwards 147 fitted as apparently they reset themselves once break in wire is dealt with!!!)
So yes any advice or contacts please and then finally I can be in control of this dreaded light and can un-strap my driver's seat from moving!
:thumbup::jester::nuts:
:smash:
