1 - 15 of 15 Posts
Is there anyone in the Grimsby area who could put me out of my misery with Alfadiag/unidiag? I can't get either to connect after 6 months of buggering about on and off and have had enuf!
I am using the latest FTDI drivers, and my cables have been tested by Smaky in who says they are fine.
When I test connection on Alfadiag (Trial version) it says that transmit and receive bytes are the same, so seems ok, but when I try to connect to ECU, I get the message that alfadiag cannot open usb serial port.
I can travel with laptop and cables anywhere if anyone can help,
By the way, Unidiag seems a complete dead loss, can't get a peep out of it.
HI
I'm no expert, but I think they do.
My ecu is as far as I know the M 2.10.3 or M 2.10.4
At present I go about setting my com port in the following way:
I go into my computer, and access device manager, hardware etc. From there I go to com port and click on the serial port, which is the only one available.
I then set everything the same as the settings on Alfadiag when I set up the interface settings.
Does that seem ok? or am I missing something?
As I say, I am a bit dim with computers at that level!
Thanks for the reply though.
Steve
Steve,
You need to select the COM port in AlfaDiag ...
When you start the program, go to Configure menu then choose Interface. Under the Driver tab, select the USB port from the dropdown list. Probably COM6 or similar. You can also test it from there ... the Test tab and select your ECU from the list ..
You should be able to do this without being connected to the car ... simply plug the interface cable in first.
make sure you uninstall any FTDI drivers & re-boot
then restart & re-boot without installing any software
then re-boot again
now download the latest drivers from FTDI Chip Home Page [ vcp type ] & install them.
then re-bbot again
when the last re-boot has happened then plug in the cable & modify the advanced option to:
rx Byte = 64
tx byte = 64
lacency = 1
also set the max timeout
also get rid of Demo [ it SUCKS ]
as a regular Unidiag user, Unidiag & its sister program KWp71 rocks ... imho its better than alfadiag for most day to day use.
Further update.
Having spent about 2 hours trying every conceivable way to connect with no success, I am going to book it in at a dealer and let them do it.
Totally had enough, will cost me, but at least I will save some time.
Thanks for trying to help everyone.
Steve
What version of "Alfadiag" do you have. Recent versions of "Alfadiag" don't need to set the COM port any more. Just push Ctrl+I and select "FTDI driver" option.
And by the way what O.S. are you using. If you're using "Vista" you might have to run the software as administrator. Don't know if this as to be done with "Alfadiag" or "Unidiag", because I only use them in "XP", but I have an ELM interface and in order to use it in "Vista" I must run the applications in administrator mode. Same thing applies to vagcom.
To run as administrator click right button of the mouse, whit the pointer over the application icon, and choose run as administrator option from the menu. And of course make sure you have the key in "mar" position, sometimes I forget and take ages to realize why doesn't work.
Hope it helps, don't give up yet.
I've calmed down a bit now thanks to an hour of The Specials from Glasto!
I'll give it another bash tomorrow!
I've only got the trial version of Alfadiag, but I would think it would link to the ecu ok. I assume my ecu is the 10.3 or 4. Engine No 62704.
I am using XP O.S. The lap top is a bit slow running, I may try shutting down everything and trying then as well.
Does it matter which USB port I use? There are 4 on board.
Many many thanks
Steve
trial version sucks .....
I don't think there is a fault now, just one still in the ecu memory. Few months ago I replaced thermostat and temp sender unit as both were faulty, which I'm 95% certain is what threw up the fault. One day I will find out!!
Hoping to have another try tomorrow, will keep you posted. Will turn off wireless too.
Discussion Starter #14
YESSS!!!
Used kwp71, got straight in no problem!
Did a stupid thing and erased fault codes without finding out what they were, but hey I can get em again!
Many many MANY thanks to everyone who replied and took the time to help.
Cheers to all
Steve.
Discussion Starter #15
Hi All
Well, the injector light has made an unwelcome reappearance!
Read the fault codes, which said:
DTC 0x08 = 8
State 7
0x11 Unknown
Condition1: 0x20
Condition 2: 0x2D
Counter : 0x42
I will now study some Greek to see what it means!!
Any help would be greatly appreciated
Steve
1 - 15 of 15 Posts
