1 - 20 of 54 Posts
im a lady owner of a alfa gta also i have a gtv i took little 1 to nursery other day and on my way home the car cut out on me and just stopped :eek: it turns over as if its gonna start but doesent i have no ingnition lights at all when i turn the key. ive had a mobile mechanic come out and he checked my relays but he said they seem fine hes checked the fuel pump and everythink seems ok if anyone has any ideas pls can you tell me so i can pass the information on to the mechanic i need it done soon as possible ;) ;) :rant: pls anyone a big thankyouuuuuuuuuuuuuuuuuuuu xx
Without hearing the car, its difficult to tell. Does it sound the same as it did before? The reason I ask is I had a cambelt go on one of my old cars and that turned over, but the sound was different because it had no compression.
Craig.
Just read your post again. No ignition lights? Forget the last post. Did he check all the fuses? There are a series of fuses dotted around the car. The relays in front of the battery are a bit crap as well. If one of those connections has come loose it won't start either.
hi babe nah its perfect sounds just fine like it did before it turns normal but just dont start but all my ignition lights are out they use to come on before now they dont its a nightmare :mad: thanks for getting back to me sweet anyway im a bit lost found this site and thought someone might know whats happened :cry:
ye hun i had a mobile mechanic on it yesterday he said he checked all my fuses relays ect he said he would be bk later this afternoon to try again and see if he could get any information on it i just thought being a woman ide beat him to it lololol
It could be a fault with the ECU. Did the fella you had round detach the battery? Try detaching the battery for a while then try and start her up. You never know. I am sticking with a fuse or relay problem!
my hubby gona pull the battery off now he just gone outside also where might we find the ecu pls ?? ive only had me alfa on road for just 1 week grrrrrr ive had it 2 yrs but i had it in bodyshop having it done up and now its died on me im falling out with it lol how did you get your picture under your name lol
If its the TSpark 2nd phase engine it should be on top of the throttle body. You could detach the leads off that aswell. It can't harm it, you never know.
You may fall out with Alfa Romeo's from time to time but you know what, as soon as I drive mine I fall back in love with her! ;)
To get a picture up just go to your account and add the avater from your pictures.
Hope you get it sorted, sounds like an electrical prob rayther than a mechanical so may be a pain but might not be too expensive! Do you get no ignition lights at all? does anything else electrical not work?
To add a pic go to the top of the page click on profile then edit avatar, you can upload one frpm your pc.
Dan
hi babe everythink works electrical stereo heater lights ect just no igntion lights engine turns over but just dont start thanks ive added my pic to but grrrrrr ya cant see the pearl in ma paint lol :D its just the 2ltre t-spark mine :D was working me way up to a 3litre and i know what ya mean ya get in and drive and love it i had gta for about 7 months and fell in love with alfas instant ;) was a new one tho i never had any probs with it so we a bit lost on the alfa side but im glad i found this site coz im sure you guys are all great :inlove:
hi sweet ye looks like that eh i thinks i better call out a auto electrician this afternoon and tie him up eya until he gets it me started lol
everythink works but ma igntion lights if i can get em on he will start lol
Palm trees in Sheffield?! Good luck hopefully its something simple, do you have an independant Alfa specialist nearby, they might be a better bet?
BTW does the code light come on and go out?
dan
Discussion Starter #15
hi dan nah hun code light dont come at all along with on dash and thanks andyroo i got me own in so dont matter about stereo code but thanks for the reminder sweet xx
Sounds again like the crank sensor problem on these engines. The ECU does not sound at fault - not fault codes, and its priming the fuel pump.
The crank sensor rarely shows a fault code. Ask your mechanic to take a look at it, it is under the starter motor near the flywheel. One bolt will remove it. They are about £13 for a new one and will take 20mins to replace.
This sensor is the cause of 90% of all non start electrical problems on these engines.
Hope this helps.
Surely if it was the crank sensor the ignition lights would come on, if the code light isnt coming on then going off the imobiliser is likely to be stopping it from starting. I think there's a major power failure somewhere, or even the ignition switch itself it malfunctioning? I'll have a quick read of the manual and will post if anything looks like worth checking.
Hope this helps.
I second this! Hope you get it sorted.. :)
Ok have a look on the auxillary fuse bracket next to the main fuse box, theres a 10 amp fuse for the code unit theres also a fuse for the injectors check that too I think its under the bonnet behind the engine (big black plastic thing. It always worth checking the easy things first.
Dan
1 - 20 of 54 Posts
