1 - 20 of 43 Posts
hi i took the plunge and put a deposit down for a 2007 159 1.9 jtd
i was wandering if you guys have seen this car before
the reg is ma07fom
thanks
Sorry to hear that, I would have called them right away. Did they offer any kind of warranty? I would think they would have some responsibility to repair it.
dont know way it broke down will find out in the next couple of days
they gave me 6 months warranty with momentum
Welcome, and ouch, not the best way to start ownership, what happened to cause it to breakdown? Lights, power?
Sent from AutoGuide.com Free App
the garage have to ring momentum. they will probably pay for the part, but only a certain amount of labour per hour.
i have autoguard, who pay £65 p/h labour, but alfa charge £80 p/h so id have to make up the difference. luckily im a mechanic
sorry to hear about your car, it obviously needs a caring owner :)
it was a power issue it would not go higher than 2000 revs in any gear
and there was slight smoke coming from the engine bay
just had enough unff to get her to my alfa guys
Check the bottom crank pulley.
The outer is bonded to the inner and when they fail the inner spins and the rubber bond smokes.
See if the aux belt is loose.
quick update the car is fudged
it needs over £1500 to get fixed my alfa guy said get a refund give it back
dealer lied to me saying the car is in good order
the alfa guys said it were a miracle i got it to them
Still no idea on the problem, if it has a warranty then why not get it fixed and repaired that way?
A real shame that you've had such a bad first experience!
When I brought mine to my local Alfa Stealer they quoted me almost £2k to get it sorted!
The list included: New EGR (Solved for about £35), new discs and pads (solved for approx £350 - £400) and a new Inlet manifold (to be fitted, but cost me £220)
So far I've spent about £650 doing it myself and I'm in the final stages! So it is possible to do it at a better rate!
After these have been sorted the next step is a remap.
I also had injector problems when I first purchased it, but these where all dealt with under warranty.
I hope it all turns out for you! Just know that there is light at the end of the tunnel! :)
Return it, you have consumer rights, speak to your local trading standards
Discussion Starter #17
getting full diagnosis first thing in the morning
to be honest i would like to see it fixed but i know nothing about these things
Discussion Starter #18
here goes
both lower arms/ n/s/f upper arm /
o/s/f droplink/ n/s/r droplink and repair running fault
TCA o/s
TCA n/s
o/s/f droplink
n/s/r droplink
1 - 20 of 43 Posts
