Anyway, I was just cleaning dead leaves from below the rear window and at the bottom of the front windscreen (my driveway is below a tree and these two areas on the 155 seem to be a magnet for leaves) when I noticed a loose cable just at the fuse boxes to the left of the n/s suspension top in the engine compartment.
There seems to be no apparent place for it to connect, and the car is OK. So, whats it for ?
Discussion Starter · #2 ·
You'll find lots of these if you look hard enough. No idea what its for but it will be for optional extra's or different versions. Presumably it is capped off ok?
wrinx
Yep, it seems OK. Its three cables encased in a black sheath terminating in a red/black female type connector. ?
I think that you might be referring to the connection where the diagnostics logger plugs into
