Great Bank Holiday, stripped out most of the inside of the gtv to find a spagetti junction of wiring, Checked the transpoder on the ignition barrel,checked all the relays I could find were tight, found wires that seemed to go nowhere or look as if they have been cut off, unplugged and re connected the immobilizer box under the dash, tried the ecu reset, disconnected the battery, checked the battery is fully charged, etc etc. After all this I still have the key logo up on the dash and the car still refuses to start.Also checked wires in the passenger foot well, and the inertia switch,nothing. Car was running perfectly untip the battery died but has not started since. Any suggestions aprt from the obvious!!
