On older cars with iron engine blocks I have sprayed a mist of water/ droplets into the inlet to decoke the combustion chamber. I have done this on the Alfa V6 but thought that I should stop as the Alfa v6 is an aluminium alloy block and head. Thus it has a lower melting point than iron. I am also assuming that the compression is a little higher than on older engines.
I want to decoke my engine with water but worry that the extra heat generated from the water and higher compression might damage the block and heads of the Alfa.
Anyone with any thoughts? Experience?
All thoughts are welcome.
