hi again,
i need to change the lights on the dashboard and to be more specific on the speedmeter. where can i find some instructions about it?
there is a screw at the top of the tube that is infront of the gauge. remove it remove the tube. 3 or 4 obvious screws to remove speedo pull back disconnect battery if not done and disconnect wires. remove speedo there are three bulbs at rear.
One small point, when you put the spedo back, take care not to overtighten the screws, the plastic taps have a habit of breaking.
thanks a lot guys!
now i will have to see if there are any specifications about the bulb or whatever this is called :)
