1 - 9 of 9 Posts
Has anyone had this problem before?
The rev counter illumination lights flicker and sometimes don't illuminate at all. Sometimes only half the rev counter lights up and at times just 4,000 up to the red line illuminates.
Sounds odd the illumination is changing?? Can only think it would be an issue with cluster rather than bulbs/LED’s so would be a cluster change?
as it's only part of the dash that has a problem, I would think of a bad trace or f.i. bad solder connection on one of the LED's or something like that.
I suspect the only way to fix it is to take out the instrument panel and have a closer look ......
Did you found the problem. Got the same issue. Only mine is on the otherside at the bottem of the speed guage
Mine has done this but not for the last couple of weeks. I give the outer ring 1 or 2 firm taps and they usually come back on.
1 - 9 of 9 Posts
