1 - 2 of 2 Posts
Just ordered some clips for airbag cover and have a couple of questions about fitting them. Do I have to disconnect the battery and do i gently pry off the cover from the bottom. The threads i have seen vary, so was hoping someone could give me a clear answer before i set the airbag off.
Many thanks
My cover is loose for some reason, I can take it off and look at the airbag and put it back with double-sided sticky tape, underneath is the airbag and they don't seem to be connected at all, basically the airbag goes off and takes the cover with it so you can remove the cover without fear.
1 - 2 of 2 Posts
