1 - 9 of 9 Posts
Regional Support North, Is there a meet near you?
What is the easiest way to drain the fuel tank on a 145? No drilling permitted
Just this once, i wont tell you to bugger off :lol:
Now then, genuinely helpful if less funny replies are accepted
Lower it down on a jack tilting slightly forward. On the front right corner there's a blue pipe, just pull it off.
This mean the conversions starting?
take the pipe off at the engine, turn the igntion on and empty it into a big container :D
what conversion is this then.......
Discussion Starter · #7 ·
No conversion yet, there is just a full tank of fuel sat there slowly going off and the Spider is nearly empty, i just want to use the fuel :lol:
Kev i'm aiming to do the 20v turbo job :)
I bought a cheap stirrup pump off eBay for aboot £8 when I wanted to drain the 155 tank (to fix sub-frame).
It's just plastic tubes but it's dead handy, once you fed it past the little hatch in the filler neck.
Ralf S.
:thumbs:
a nice conversion that's mechanically very straight-forward.
getting the electrics to talk to each other was the tricky bit, but then you can get around a lot by getting the code system removed from the ecu.
be nice to follow another one ;)
i'm still hankering after doing a 16VT one now...
1 - 9 of 9 Posts
