1 - 16 of 16 Posts
· Registered
I have recently bought a bicycle and want to go farther afield but am wary of boot mounted cycle racks as I have heard horror stories about them damaging the bodywork. I would like to get a tow bar fitted to attach a cycle rack but am not sure if this would interfere with my parking sensor which was retro fitted. Does anyone have any experience of either?
· Registered
Hi Mardy,
Try this link as there is a photo I have attached of my Dads mito with a tow bar fitted for exactly the same purpose as you, he has factory fitted reverse sensors and hasn't mentioned any problems.http://www.alfaowner.com/Forum/alfa-mito/228801-mito-tow-bar-bike-rack.html?highlight=tow+bar
· Registered
Was £600 fitted for an Alfa detachable t/bar a year ago or around £350/400 for a Brink, Witter or Westfalia. Brink is less visible with the ball removed but Westfalia has the best release mechanism according to my local t/bar dealer/fitter. I've not had a problem with it.
Fitted it needed two cuts to the underside of the diffuser but according to the fitter a template was supplied with the kit so made it easier. Socket is retractable so all that's seen without the ball is a small 3"x 2" cover. Parking sensors are unaffected.
I was looking for the least conspicuous without the ball fitted and reckon the Brink/Thurle is pretty good on than score. £396 including fitment.
Don't worry, It's for my motorbike trailer, not a caravan! :D
· Registered
I've just ordered a 22.5 inch cycle (not a Mountainn Bike) and I'm hoping it will fit inside my Mito. I'm willing to take the front wheel off and I will not have anyone in the passenger seat. Does anyone know if it will go inside the car?
I fitted my own bar in a couple of hours. Only holes not already there are for bumper cut out, measure that several times before cutting and you're sorted. Bumper cuts with Stanley knife.
Got bar & smart electrics for £10 used off eBay!
No problem with parking sensors, though of course they don't work when you have something attached!!!
· Registered
When you say smart electrics? What do you mean, is it a universal wiring kit?
The model specific wiring kits for the mito start at £150? Plus the towbar in the case of the Thule brink your looking at £300-350 parts alone plus fitting.
You got very lucky getting all that for £10. Got mine for £70 but need electrics and never got round to fitting it.
You need a smart relay which works with multiplexed wiring, they're not model specific, and not hard to wire up. I found power for the relay behind the carpet on the left, there's a fuse and relay box for the back of the car... Each function is connected to relay along with supply and ground, then your 7 pin sockets connects to the outputs on the relay. Had to do same on facelift 156 - anything with bulb check will be upset if you don't use relay.
· Registered
Bike will fit in easy with back seats down and front wheel out.
I've even had a 250cc motorbike with no wheels on in the boot. Couldn't get it out though! :eek:
1 - 16 of 16 Posts
