really, 80-95Ah is size of battery for cold markets 2.0+ liter diesel engines where you need glow plugs preheating and with this load you need to start engine which is much harder to start than petrol (much bigger compression). For petrol engines 80Ah seems excessive. Problem is elsewhere, charging mainly, S&S if one uses and a lot of energy vampires working all the time (keyless , Alfa Connected Services etc). In terms of quality of batteries, I have some doubts - one guy from polish forum was towed3 weeks after buying car as battery decided to die - nonetheless he driven day before longer distance. Replaced and no issues since. My case - started having issues afer a few months, at 8 months battery replaced as was permanently causing issues and charging was resolving for short time. Eventually it failed on tester and was replaced. New battery I have for more than 1 year and no issues (just had to charge it yesterday, car barely used and only on short distances, IBS started showing 37%, charged OK, open circuit voltage 12.91V a few hours after charging)
