I bought My Alfa 147 about 6 months ago, however, my cruise control doesn't seem to be working anymore. Anyone had this issue before and could assist me ?
Check the switch on the clutch pedal and also the one on the brake pedal.
Agreed - plenty of threads about this, and I cleared the problem on mine simply by pulling out the plunger on the clutch switch and gently letting the clutch pedal return to its resting point.
You can do it yourself if you get your head in the footwell you'll see the switch under the pedals. Just pull,out the plunger gently press pedal and then go for a test.
