my cruise control light dose not come on the dash any help please
but will the dash light come on if the switch is stickingDoes your cc work? If not check your brake and clutch pedal switches if they are sticking will cause cc to not function
no everything else is okAnything else not working/lighting up? For example on the GT the cruise fuse is shared with the climate control backlighting. Your manual will tell you if the fuse is shared and with what.
i will try when my wife gives it back to meNo idea. I imagine not. As a sticking switch will send a signal that either the clutch or brake has been pressed which will turn off cc.
Try pulling out the plunger a few times to free it up then pull out as far as it will go then go for a test run.
Like Mike asked, is the cruise control actually working? If not then you're probably looking at wiring or the switch.no everything else is ok
no its notLike Mike asked, is the cruise control actually working? If not then you're probably looking at wiring or the switch.
What car is this? The 147?but will the dash light come on if the switch is sticking
147 1.6 2001what car is this? The 147?
On the 156 the dash light will come on even if the brake is pressed, the switch is malfunctioning etc - i imagine it's the same on the rest.
Not on my 2.0 ts 2001 147 it was sticking clutch pedal switch but no light came on reset plunger on switch worked fine.What car is this? The 147?
On the 156 the dash light will come on even if the brake is pressed, the switch is malfunctioning etc - I imagine it's the same on the rest.
