159SW, 1.9 16v 110KW diesel
Hello
The title says it all. I'm trying to get behind how the cruise control lever is connected to the ecu. According to this [GUIDA] Cruise Control Aftermarket.. - Alfa Romeo 159 Owners Club guide, you must connect the cruise control to the D001 socket in the car.
To do it correctly, I'd like to know how the cruise control lever is layed out inside the lever, which pins short to which pin, and what each individual pin does (acc/res/on-off etc).
Does anyone have some documentation on these matters? An overall car wiring diagram would be extra awesome.
Cheers and thanks
Info: 2007 159 SW, 1.9 110KW(150hp) diesel, automatic gearbox
The wiring diagram can be found in eLearn.
eLearn copies can be found on eBay or it is possible to download from internet. Try to google Alfa 159 eLearn
I have attached the wiring diagram between the cruise control and ECU
H007 is the cruise control and M010 is the ECU
Thanks alot! That was exactly what I was looking for.
Do you perhaps know what the resistor values should be for H.V part?
Thanks again
