1 - 20 of 56 Posts
My Quad has just hit 27000 miles and ive noticed that the ride is a lot crashier and more figity than it was previously.
Has anyone else noticed the ride comfort decreasing as the miles go on?
Could the adaptive damping be stuck in hard mode?
Still wearing Corsa's and down to their limit? I had the same symptoms with mine, switched to mps4s and much smoother, even in cold weather.
I'm at 19,000 miles and nothing has changed.
As has been said, it might be a damper on its way out or the control of the dampers failing.
How does the ride compare in A, N, D(Normal), D(Soft) and Race? If all were similar, it might indicate a control failure.
When I had a suspension control failure on my Mito QV the ride became very harsh. Fortunately it was a just software glitch which reset itself.
Andy
So I experimented a bit on the way in today, it seems to ride smoother when the Dampers are set to medium. Soft appears to be a bit too soft now and the car kinda wobbles about.
Can you reset these cars by disconnecting the battery for a short while. ?
Sent from my F5121 using Tapatalk
Yes, but it is likely to cause more problems than it solves.
Andy
Alfa do have a habit of fitting not the best quality dampers.
The Giulietta ones (Made by sachs) could be quite poor after not that many miles.
31000 miles and no sign of any problems. Still wafts around like a Jag in A mode.
It amazes me how well they ride in soft...Even with lowering springs in its still really comfortable..
I recon a duff shock is causing this, the front shocks in my RS4 went (common problem) and it felt very crashy while at the same time being bouncy
I have also found a bit more waywardness at the rear I am on 28,000 miles and a couple of time the roadholding has seemed a bit vague, it has only been a couple of weeks after its last "dealer" service. I am going to get the shocks checked out.
My car is a March 2017 delivery and only covered 8000 miles. last week its developed a noise that occurs over small bumps. Sounds like the rear passenger side shock, top mount or similar from experience. Could be a suspension bush or spring perch. Im not even sure if there are sway bars on the rear? I guess it could be a bearing. None of these things seem right for road only 8000 miles. I would have it checked out but the dealer is 200 miles away and no doubt would need to wait for parts etc. I jacked the car up today but the rear passenger side wheel feels ok. Tyres are more worn on this side than the other (center to inside shows the least read, outside has plenty). Id guess Im up for new tyres in 2-3000 km. These are the Corsa and I have a new set in my garage for when they are ready. Bit stumped really, doesn't seem a safety concern and handling hasnt changed so bit puzzled...
Had the same issue. Booked in for first service and they changed the top mounts (only front).
Quite now. But the ride quality wasn't effected before or after, just the noise at cold when passing small road bumps, after driving for 3-5 min nothing.
ionutp. Thanks for the intel. Very interesting to know. I am not going mad then thinking this isnt possible on an 8000 mile car. Its very hard for me to say, it could be coming form the front, but I suspect the rear and the noise is consistent with the sound I heard in my e39 M5 when the rear top mounts went. Those e39 5 series were prone to the issue but would usually cover at least 20k miles before the issue surfaces. Similar weight and general performance in the M5 variant to the QV I guess but still they are obviously a weak point...thanks again - would be interested to hear from others with similar issue. This may also be the issue the OTP is experiencing?
Please keep us updated on your progress with the dealer here. I’m now fairly certain the noise I’m getting from the rear is a failing shock. I have not identified any handling traits yet but will go for a proper drive today and advise...
Discussion Starter #20
Well mine is back at the dealer to have another look at pretty much all the issues reported at the service which they didnt identify
1 - 20 of 56 Posts
