Hi all does anyone know where the crank sensor (for timing ignition)is placed for a Busso engine (2.5) i know that with a 4 cilinder its placed at the starter motor but i have no idea where when you have a Busso.
Thanks in advance.
As above, it's bolted to the sump above the front pipe and a heat shield - see pic below, which is upside down if you see what I mean. Crank sensor is behind the bit with the bolts circled green;
