I live in Clayton le Woods G&S auto electricians in Chorley have a good reputation they are on the estate near B&Q and Aldi The dealers wouldn't be Blackburn Motorpark by any chanceFeel better after these comments. I did feel a bit suspicious after they told me this and just said its an expensive repair around £900 but didn't give and exact figure! I live in Chorley Lancashire of anyone can recommend somewhere
Probably only been there once for a small warranty job wasn't impressed with the whole experience.I had it booked in at G and S the day after I took it for the oil service. But panicked when the dealership told me the cost so cancelled it. I rang Alfa direct and I'm waiting for them to call back. You're right the dealership is Blackburn. Do you think they've panicked me for no reason?
I had my hatch cables changed under warranty and was done as a precaution while it was in for the GPS antenna base to be changed, they were very good but unfortunately this Manchester Alfa dealership has now closed down. The bad thing is we don't have many respected dealers left in the North West so Alfa better get this sorted before the Giulia arrives.Ok. Back at the dealership today for a separate reason. I've asked more questions after all this advice. They are now saying that it's not corrosion but like someone on here said its a known fault where when the back is opened after a period of time it breaks the loops. They said that you can repair this for cheaper but the problem with still happen again and they are suggesting they replace the whole thing with a newer wire that doesn't break. They also said that they made a mistake a the heated seat isn't the same issue and maybe it's a heating element. It makes me so cross!
I'm going to wait to to speak to Alfa next week and see what they say about the fact that it's an obvious known fault so shouldn't be put in like that then book it in with G and S.
Does this sound ok?
Yes they do. . . and work harden!And one other thing copper cables do not corrode :0)
