1 - 16 of 16 Posts
Just wondering if anyone has used copper sheet to make exhaust gaskets for their car???
I am getting sick of using the std ones that fall apart and providing both mating surfaces are flat it would be an inexpensive gasket that you could re use?
K
quite a few inlet manifold gaskets are now just steel rather than fibre type ones.
have even mounted turbo's to exhaust manifolds with no gasket, a thin smear of copper grease is all that is needed to seal it as long as the faces are perfcetly flat and soptlessly clean..
Cheers guys, yes i have just obtained a .9mm sheet of copper and will start cutting and drilling to make a set of reusable gaskets.
Will post some photos of how it turned out.
K
enough material left over to knock up a few sets and pass them on to fellow boxer members ;)
:D
Have you tested these yet? Good seal or any leaks?
Stupidly enough last night I threw out an old water boiler that had a tank made from Copper!!!
Just thought afterwards I could have utilized the copper.
(also for my valve amps I build) :rant:
...plus electrolysis copper-paint for some parts or bolts......
:cry:
It was sitting outside for 4 months and the day after I throw it out I realize it could have been used!!!
Shoot me!
:cry:
Shoot me!
K
a copper tank would never get to sit outside over here for 4 months. houses have been broken into and the water pipes taken out to be weighed in for the extreme scrap price of late, a handy big lump like that would get the pound signs going in some locals eyes :lol:
scooby/ reliant exhaust gaskets fit if you open the holes up slightly, i've been using them yrs, easy to get hold of too
1 - 16 of 16 Posts
