1 - 2 of 2 Posts
My 159 has an odd problem in that the cooling fan comes on even before the temp has started to register on the dial, and then stays on most of the time. It goes off occasionally but randomly, not with any apparent reason.
The car has an AHM custom remap, the coolant levels are fine and I'm also using Water Wetter. The gauge registers a normal temp (with the needle at the 9 o'clock position) and the engine isn't running hot.
Any ideas please? Map issue?
Thanks :thumbup:
I'm pretty sure the fan is supposed to come on with climate control. Regardless of engine temp ??
1 - 2 of 2 Posts
