guys got a water leak somewhere at the bulkhead. can see water dripping onto the steering rack around the power steering fluid tank area.
any ideas whats leaking and how hard it will be to fix?
cheers :)
It's definately not screenwash?
(Mine used to haemorrage screenwash when warm.)
Suggest adding a dye (fluorescent if you can get it), run the engine up and then use a UV light (Maplin's do them for not much cash).
Worked for my screenwash leak.
Happened to me a while back.... turned out to be the heater hose that runs to the climate control system which is mounted on the bulkhead. A complete pain to replace. Mechanic did a temp fix by cutting the hose and U-ing it back, thus bypassing the climate control. But doing this will mean no heat, and the climate control will act erratically in auto mode.
