I have small coolant leak witch i thought ut was from the radiator but this morning i discovered a leak from the place that i have attached in the pic. Is it fixable and whats tne name of the part? Its alfa romeo 147 jtd 85kw 2004. Thanks
934032
Discussion Starter #2
By the way this is my firs post, and i have the car for 5 years and you guys were very helpfull trough the years. Thanks a lot for that
I would class that as a coolant rail/manifold,difficult to tell from pictures but looks like there should be a bleed screw in there?
No reason why you can’t weld it up, is it just the bleed screw has bust off? If it is you could remove remains and replace it
@johnnyroper its not the screw, there is small hole on the pipe and theres leak from coolant, i dont understend how the hole was made 😁, but if it can be welded then it will be an easy fix. Thanks a lot 👍
