Can any one pleasew tell a newbie where the radiator drain plug is located, so I can change the antifreeze please?
There isn't one .. you have to disconnect the bottom hose .. but do this at the THERMOSTAT end, not the rad end or you may not be able to connect it again.
If you have the original hose clips, you will probably have to wreck them to remove them and replace them with jubilee clips.
You'll never get all the old coolant out, but if you mix it at 50/50 or buy it ready mixed, this should protect your engine down to temperatures well below anything the UK gets ...
Thank you very much gary, thought I was blind not being ablre to find a plug, bad design flaw there, cheers John
