1 - 10 of 10 Posts
Changing my thermostat today and the plastic coolant bleed screw in front of the engine snapped off like it was made of chocolate.
Questions as follows:
1 - how do I get out what's left without dropping bits in to the system that could cause problems or should I not worry too much and just flush through with a hose? Will this area flush through from the header tank if the engine is cold?
2 - can anyone tell me thread size to get a replacement?
Thanks folks
Also had the throttle body off and have some pics of the inlet manifold I will post up. It is absolutely caked! Will have to come off in the near future if I want it to run right.
If there is still enough plastic left in the hole you may be able make a slot for a flat blade screwdriver then screw it out. As for the replacement search for 'Give away'
Tracer
I think you can buy metal ones frm Alfaas the 156 uses metal one,s. TThere was a young lady on here giving them away . check out old post.
Maybe leave it in place and secure with a jubilee clip and aradite epoxy 2 pack glue. Or that putty 2 pack that repairs cracks in central heating pipes.
I will post a picture tomorrow, but I had the same problem 2 years ago when away from home and I put a self tapping screw in the plastic hole to get home and it has never leaked again. Its still in there.
I'll have you know that I'm not a young lady, so far I have given away between 30 to 40.
Ben yours will be sent tomorrow.
Regards
Tracer
1 - 10 of 10 Posts
