Hi All,
I'm about to remove the brake and clutch reseviours on my RHD 1750GTV to paint the areas around them which have been ravaged over the years by spilt fluid. Currently the reseviours appear to be joined to the hard lines by manky old bits of hose and I'm wondering if anyone can let me know if flexible lines should be used for this and, if so, what type of hose I should use for DOT 4 brake fluid?
I assumed it was a lashed up arrangement, but looking on Classic Alfa, their photo of a new reseviour appears to show what I assume are "push" fittings on the bottom. Also their hard master cylinder to reseviour line only has one screw fitting (for the master cylinder) and the other end is a much smaller fitting.
What has confused me though is they don't sell the bits of flexible hose specifically for joining the reseviour to the hard line, and all the motor factors I tried today don't sell flexible brake hose by the meter either...
I don't think fuel line can be used for this, so if someone who has done this job can advise what they did it'll be much appreciated.
Thanks,
Alex
Thanks,
Alex
