Looking for a bit of help with my coilover setup.
I have purchased the Eibach Pro Street S kit and am looking to have it fitted in the next week or so.
In the technical data for the 147 GTA it says the following.
Approximate adjustment range A in mm is 25mm for the front shock and 35mm for the rear.
Approximate wheel hub centre to wheel arch measurements are
Front 335mm to 360mm
Rear 340mm to 375mm
I have measured the stock suspension and maybe coincidentally, maybe not, the stock hub centre to wheel arch is approximately the same as the maximum height adjustability of the Pro Street Coilovers.
I found a good explanation and schematic of coilover design (attached) on another car related site which explains that if I set the Spring Perch to maximum height adjustability I'll have minimal up travel as the spring will be compressed, setting to the lowest point would have the opposite affect (hope I have that the right way around) so I need to choose a setting that is somewhere midway or a split like 60/40 up/down travel.
I am planning on going for the following.
Front - Going for a initial hub centre to wheelarch measurement of 350 with settling getting me into the 345-340 range
Rear - Going for an intial hub centre to wheel arche measurement of 355 with settling getting me into the 350-345 range
A total lowering of
Front up to 20mm
Rear up to 30mm
Can anybody give me an reasons to change these settings? I've gone for what I think may still give travel in both directions whilst giving me a decent drop. There's been no precise science though and have no idea how this willa ffect handling.
The roads where I live have lots of unexpected changes of cambers and dips and crests (Pennines) and I mainly drive back roads with a small amount of A roads.
Any help much appreciated.
Sean
Rear 340mm to 375mm
A total lowering of
Front up to 20mm
Rear up to 30mm
Sean
