· Registered
Can anone tell me why, on my 1.6 ts 147 that the coil packs on cylinders 1 and 2 are on the larger of the two spark plugs and the leads off the packs go to the small plugs, and on cylinders 3 and 4 the coil packs are above the small plugs and the leads go to the large plugs :confused:
· Registered
Discussion Starter · #4 · (Edited)
Found this on alfaworkshop, if you look at the pic ,the chrome parts (the parts that fit down the tube and onto the plug) that attatch to the small plugs are to the inside from both sides. The plug sequence from the cam belt side is large,small,large,small,large,small,large,small, does this make sense :confused:
· Registered
I don't suppose it matters as long as the firing sequence of the plugs is right, it just seems a little odd, just a quirky Italian thing maybe :confused:
