Hello I really need some help!
I have a 156 Tspark 2.0 98R
had a problem with rats nesting in engine bay and chewing through three of the connectors at the top end closest to the windscreen(sorry i dont what these are called).I have repaired the connectors and put back but now car is not firing up,had diag done and turns out there is no power going to the coils but there is power going through elsewhere on the loom...?
So my question is what could be causing it and what do i need to check/look for....
ANY HELP WOULD BE APPRECIATED:cry::confused:
:confused::(:confused::(:cry:
You have
rpm sensor
cam angle sensor
detonation sensor
lambda sensor
solenoid actuator connector
Looking at the car from the front which ones did you repair
It was def the lambada sensor and then the two connectors next to it...
I am not being very helpful i know but if it helps the ones after the lambada sensor had a white connetor then it was brown...these are the only ones that were chewed,i will try and get a picture of the ones it is and post it
thanks for reply
White connector: knock sensor (engine will run without this)
Brown connector: crank sensor; this is likely to be the cause of your problem.
What were the actual errors read from the ECU?
Did you check voltage at coils while cranking the car because you obviously will not get voltage at ignition on.
