Hi
I am having some issues with a troublesome grey spider Phase 1 1997. Bought as a non-runner following an overheat five years ago, I sorted the head, water pump, rad, new cambelts etc etc but it will not start due to the CODE light being on.
As I also have a 1998 Ph1 spider on the drive ( :biglaugh: ) I took out the ECU, Code box, aerial and key and used those to try and start it, and it failed, CODE light still on. Put them all back in the red spider and it started straight away.
So I have concluded that there must be a wiring fault, or faulty relay or popped fuse in the grey one. The fuel pump fails to prime on turning the key. I have swapped the relay around and still no joy.
Firstly have I drawn the correct conclusion, and secondly, where can I find a wiring diagram for the CODE system to help trace the fault.
Thanks in advance guys
