Replaced the clutch, pressure plate and bearing recently, car feels much better than before and puts the power down great but I am noticing some slight rpm vibrations in the clutch pedal when shifting at higher rpms, it not a judder or rattle just slight vibrations, it is only noticable when the car is in gear and above 2k rpm. The flywheel was not replaced but seemed to be in great condition, no burn spots and minimal movement, also had a mechanic check the flywheel and it was all good according to him.. Anyone else that had this issue or knows what could be causing it?
Btw the car is a 07 gt jtd.
Skickat från min Nexus 6P via Tapatalk
