Done a quick search but not found anything that matches the slight issues I've got at the moment.
Key in the ignition and everything lights up ok, wait for the message push clutch or brake and press starter. I push the clutch pedal down and hit the starter button and the lights go off. I can try this a number of times before the car actually starts. Or, I can just press the brake pedal and the starter switch and it fires up straight away.
I suspect that the clutch pedal sensor is worn out? I'm going to replace it as soon as I can find a decent one. Can anyone recommend a maker/source? Or even confirm you've had the same issue?
Guy
Guy
