Howdy all,
Quick question guys, is the Clutch Position Sensor the same as the Input Shaft Sensor (that usually pops up for the diag code P0720)?
And, whether they are the same or not, how much do they cost and where can I buy one from?! :) I need to replace the latter one as it's producing fault codes.
Cheers chaps.
Ben
Clutch Position Sensor is a black 'pot' held in place by 2 torx headed bolts.... iirc approx £70 from dealer
the speed sensor is screwed into the side of the egar box, just bove the reverse switch & below the filler bung.
I assume you refer to a selespeed gear box
Ahh thanks for clearing that up, yes it's the speed sensor I need to replace. Any recommended places to pick one up from? Not that I want cheapy products but if I can pick one up outside of a main dealer and save a few pounds then lead the way!
Cheers,
Ben
Alternative Autos
[email protected]
he'll probally ask for last 8 digitds of chassis number
