i posted earlier about car not finding reverse from neutral position can only get reverse after engaging first gear, not to many replies so if anyone has any ideas would appreciate it,also when the car drops gears from 5th-2nd it is smooth as a baby bums, but when i go from 2nd-1st there is a noticable noise like a clunck sound as it drops into first, is this normal????( i forgot to say its a new gearbox)
It is on my 147 Sele (original box), always does it. If you just turn ignition on (not start engine) and go through the gears you'll hear a clunk in every gear change. (I do this to pump up the system to check the sele oil level)
Try that Tech link heading by Paul Denyer, so,comprehensive, but of course does refer to Examiner quite a lot. Good Sorting.
cheers, will do that
