IMO this is probably made substantially worse by the dirt which accumulates on top of the spring seat. This dirt gets wet and promotes rust, largely because it takes quite a while for the wetted dirt to dry out. This takes a long time because the dirt is not exposed to significant airflow, but is trapped in a space / void created by the pressed metal spring seat and by the rubber diaphragm which sits above the seat and beneath the spring coil.
The problem is that the lower 'spring seat rubber' isn't only a separating rubber membrane (located between the coil and seat), as it should be but for some reason isn't. It is also formed as a 'sheet' extending inward so that it is in effect a thin rubber diaphragm which creates a nearly enclosed void above the pressed metal spring seat. This void is not fully sealed so dirt and water can enter it via the drain hole (in the metal spring seat), and a small gap where the diaphragm sits around the outer damper tube.
The void is a space in which over time dirt collects, and when water also enters 'mud' is formed. Since the void is not well ventilated (only by the small drain hole - probably partially blocked - and the gap between the 'diaphragm' and damper body), the wetted accumulated entrapped dirt will remain wet for substantially long periods of time, particularly in rainier / cooler / more humid weather conditions. The trapped moisture will breed rust and so the spring seat will rot, and the longer the accumulated dirt remains wet the worse this will be. Salted roads wouldn't help...
The mud is more likely to dry out more readily and more often if the void is well ventilated. The best way to ventilate the void is simply to eliminate it, by cutting the 'diaphragm' away until only that part of the rubber sheet which sits directly between the coil and the seat remains.
Admittedly, dirt and general debris will now more readily collect in the 'well' at the base of the spring seat, but once wetted will tend to remain wet for a shorter time because there is now a great deal of airflow around the dirt sitting on top of the spring seat. Also, if the rubber diaphragm is cut away it becomes possible to hose out collected dirt / debris / salt(?) from the spring seat, which is impossible if the diaphragm is not so 'circumcised'.
The "diaphragm" is shown in this diagram:
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.
www.bing.com
marked as part #1
Having written this, I have to admit that this is only speculation based on what I see in secondhand reports and photographs. I have never seen rotted spring seats, I assume because compared to much of Europe the Oz climate is not so wet, not so cold, not so humid(?), and the roads are never salted...
Regards,
John.
