1 - 15 of 15 Posts
Bazza my old friend..long time no see..
the 75 diff is a plate differential..one set up primarily for road use with something like a 40% slip. These diffs can be uprated by adding cluth plates and ramp angles. The diff and box are realy only good for 300 horses..any more and u need to think about proper gear kits etc..
Best way to get 350 eh?? hmmm my mate had a full hit 3.5 12v..cams throttle bodies and the biggest valves possible..and its 300 at the wheels..and it cost 14K !!!
For a 12v to kick 350 ud need either to go 3.8 (100mm pistons/liners and a GTA crank and rods) with lots of work..£££
or
24v with less work but still a fair bit of £££
or supercharger kit from the states at about £1800---gives 300 gggs on a near enough stock 3 litre..
orrrrr turbo...u can get 450+ but ull end up with a Getrag or ZF gearbox and a rear diff...
Talk to Aidie at AHmotorsports..he did the 3.5 for my mate and a 3.8 race car with 400 gg's...
My 75 is havin a 24v next week...then throttle boddies...all for the road lol
Laterz Pilkos
so how much will cost for ur 24v work done!? and how much bhp will it be?
i think this is da best way without putting more weight on da car , won do any good for power drift!?
ahhhh appologies..it was indeed another Bazza I used to know..
My 24v convo is basically a 45k milage transplant..got the engine cheep..£500..and a 75 specialist EMC racing in Surrey are dropping the motor in, fabing up exhaust downpipes and getting it running for me.
The std 24v with a streight through exhaust and a proper air filter should be good for 200 at the wheels.
Later Ill get the programable ECU done by AHmotorsport and when pennies allow get throttle boddies later.. Check AHmotorsport web site out for an idea of prices
Pilkos
well i do supply emc with all his veloce and evo bits yes...we are intending doing an imsa kit soon though..bit it will be wide and ud need something like 10 and 12 x 17 or 18's to fill arches...
imsa!? wow that da one i want , but i just bougth a set of 17 inch kei racing wheel size only 17x7 215/40/17 tyre may be wheel spacer will do da job!? anyway how much is da imsa kit cost!
I got same size on my 75 and they go underneath std arches.. They are completely the wrong ofset for the imsa arches. The overall track of the car is increased by about 8 or 10 inches so to fill those arches ud need wheels with a large outward offset and probably split rims at that.
Dont know what the kit will cost yet but it wont be cheep because it would have front n rear bumpers, front wings, sills, rear door skins and rear quarter pannel arches..
Ian
is there anything good or cheaper to order parts from south africa for our 75!? cause i came from south africa! and still have friends there who can order those parts for me!
Administrator
This thread is fascinating, I can't decide what is making it most difficult to understand for me. Is it the fact that I know nothing about lsds? Or is it dat dis txtspk is cmpltly impssibl 2 d-sifr? ;)
Out of interest though, does typing 'da' instead of 'the' actually reduce the amount of calories you have to take in per day, because of the extreme reduction in effort?
I feel a bear hunt commin on...now where's my van...
Administrator
:cheese:
I reckon I asked for that :)
1 - 15 of 15 Posts
