1 - 9 of 9 Posts
Since fitting my HID kit i am becoming less happy of the overall look.as im soon to be doing the gta mod to some headlights. i notice newer cars have Clear headlamps thus showing a huge improvement in looks if Xenons are fitted. so would like to achive a better overall look.
Does the GTA have clear lamps? as the pair in mine are not clear so i get too much light spread inside the lamp, which im not as keen on.
is there a way round this or are there different lamps available?:confused:
Discussion Starter #2
Also is there a way to position the bulbs lower as there blinding other drivers :lol:
the dip switch doesnt do much at all.
im sure there is another way under the bonnet?
What do you mean "clear lamps"...?
The front of all of them should be clear!
yeah perhaps mine are just dirty, im after crystal clear. and more of a concentrated beam.
They all start crystal clear and gradually get dirty on both the outside AND inside.
When you strip them down you can clean & polish the inside.
ok david thanks.
for some reason i thought older cars had a different quality of lens.
is there a way to adjust the beam height while your here ? :)
yes, using the adjusters on the back of the headlight.
You need it on a proper garage beam setter though to get the aim correct.
Rule of thumb:
Top of the beam should be 2 inches lower than the top of the headlight at 25 ft.
1 - 9 of 9 Posts
