1 - 10 of 10 Posts
A little birdie whispered in my ear that I should consider fitting coil packs from a late model 147 on the 146 as I will then get a cleaner spark and therefore better combustion, which of course will translate into better gas mileage or (the way I drive) better performance. Now I don't even pretend to understand this. Therfore can someone explain why this may be true, as to me a coil pack is a coil pack is a coil pack. What is it ie better or less resistance or whatever that would make this happen?
hi...i can probably imagine this will cause managment issues?But i dont see why its not possible...speak to the electric guru - Chris.
joe,I think that's a load of ********.
I would think the ECU would be your first port of call.
For the older cars, Bosch blue ending in 027 is seen as better than other coils. I don't understand coils either, but try the electronic management forum on alfabb. Those guys know everything!
I'm with Cerrone on this, not to convinced of this.
They both Twinspark engines... I think they even use the same spark plugs... I reckon you better off just putting a new air filter in.
Good to see you back Joe.
I can't quite remember the details, Chris explained it to me. The way the second spark plug is fired is different between the 2 motors. But in what way I can’t remember.
It is said that the way it's done on the 147 is better. I would hope so, since it is the later model and should be an improvement. If the coil packs are a straight swap is another thing altogether and so is should you.
Well that’s my lame 2c.
ryan, if I remember correctly it called wasted spark, it concerns swapping the second coil plug...as far I remember the guys said that it yielded no results.
will try and look for that info...
Lol, yeah. Remembered it had something to do with wasted spark, but I just can't recall the details.
Yeah, hang on. On the 147 the coil fires the main plug and the second plug on the same cylinder via a lead. Does the older one fire the second plug on another cylinder? I have this idea that on another TS engine it's used this way. This is from a casual chat, a longish while back so, it's very fuzzzy.
As for results, I can have no opinion.
Same as my cars coils vs a newer twinnie.. The coil packs have a short lead for the 2nd spark plug so 1 coil pack fires 1 cylinder, on my car the coil pack fires main sparker in cyl 1 and secondary sparker in cyl 3 etc...
What the difference is.. I dunno.. Although the specs say my car is 114Kw and the newer ones are 110Kw... Maybe one of you boffins can explain this to me?? I think its because the newer twinnies have more Cats than mine??
i think its coz of more cats mate...earlier mofels have less cats...maybe 2 and newer models like mine have 3 it has 2 at the manifold and 1 just after...
1 - 10 of 10 Posts
