Just looking at your Avatar pic, it looks like Alfa red - 289/A, which is the Rosso Allfa 05+.Just looking into getting some chipex. The red options are either:
Rosso Alfa (05+)
or
Rosso Rubino (05/10)
Any ideas which I need?
I think we posted at the same time!Rosso Alfa, Rubino is the red wine colour and i'm pretty sure that wont match on your car!
Let us know of your results. I have a few chips and I'd like to know how the chipex kits, which are pricey compared to the rest, performs.
i had a go with mine this weekend your right it takes a bit of practice the problem i have was getting the excess paint of with the blending solution i felt i had to rub it hard to get it to come of which in turn took the paint in the chip offI think we posted at the same time!
The kit is good - colour match (for Rosso Alfa at least) is spot on. It does take a bit of practice to get the technique right, ensuring the right amount of paint is applied and patiently taking the excess off with the special solution.
It might take a couple of layers to completely cover a chip and make it flush with the rest of the paint, but as the colour match is good, a single layer is acceptable for most chips.
Hope that helps!
P.S. The often have discount codes available for AO members offering a 25% discount - worth a look!
That was exactly my problem! After giving the guys at ChipEx a ring, who were very helpful, I had another go. The trick is to only use a very small amount of the blending solution, and using the 'flat' part of the plastic card thing (as opposed to the edge that I was using). Then its just a case of patiently and lightly rubbing away until it starts to come off.i had a go with mine this weekend your right it takes a bit of practice the problem i have was getting the excess paint of with the blending solution i felt i had to rub it hard to get it to come of which in turn took the paint in the chip offwill have another go this weekend.
Cheers for the advice patience is where i fall down:lol:That was exactly my problem! After giving the guys at ChipEx a ring, who were very helpful, I had another go. The trick is to only use a very small amount of the blending solution, and using the 'flat' part of the plastic card thing (as opposed to the edge that I was using). Then its just a case of patiently and lightly rubbing away until it starts to come off.
A lighter touch and more patience basically! When it starts to come off, there will be a limit to how much comes off as you've only used a small amount of solution, so just use a different bit of cloth with a bit more solution.
This approach has tended to work for me, although if too much paint is applied it can be very trying!
I still haven't worked out how to address the 'road rash' on the leading edge of the rear arches though!
No problem!Thaks for the colour and technique advice!
I would have probably fallen down the same hole of applying brute force rather than patience
As for price, it doesn't seem that bad at £50? How much are the alternatives.
A tenner in halfords?Thaks for the colour and technique advice!
Yes, but this doesn't work half as well as Chipex/Dr Colorchip solutions.Think I paid £11 for the official Alfa touch up.
