1 - 10 of 10 Posts
hi all,
i wish to charge my battery...
what would people recommend?
i intend to put it on a very slow charge. but not disconnect the earth.
is there a problem doing this ??
or does everyone recommend taking off the earth wire?
cheers :)
Another Alfa myth. Put charger onto battery, switch on. Nothing will explode, no memories will be wiped, no ECUs will fry. Keep the faith :)
Quite likely to damage the alternator though, especially if you use a cheap charger that not rectified very well. That doesn't only apply to Alfas.
Discussion Starter #8 (Edited)
i used to charge my last car, a 2002 golf, with no hassle, the charger is new and pretty good, with a 6v or 12 charge and a slow medium or fast, i obviously choose slow :)
i may charge the battery and use it as an excuse for an ecu reset :)
and i usually connect the charger leads, then connect the power, that way there are no sparks !!
i charged the battery in situ.
no problems, did a trickle charge.
all is fine, nothing blew up and the battery is now fully charged.
All my cars are fitted with a fly cable to the battery, kept batteries charge up last year in the cold weather, never a problem. Connect and be happy.
1 - 10 of 10 Posts
