Hi guys,
when changing a turbo on a Giulietta QV 235 HP, can you interchange it to a 240 HP one?
Will it give more power and does it fit as the 235 one does?
cheers :blabla:
Hi its not that simple.
The 240HP is Vacuum controlled. the Old Control the Wastegate with overboost from the Turbo itself.
You need to change the Wastegate and drill 1 new hole, and also need to open an existing one.
Also you need to make 2 new Pipes for Hose connector for the Turbo control.
Hopefully i helped you.
