Hello,
I just tried to get them out, but without success. I couldn't access the upper bolts and nuts. To me it seems that I have to get the fuel tank out, but first I wanted to ask here, before doing that if there is any trick on this?
TIA
amir
TD 2.5
if you jack it up and look just above the rear wheels in the subframe you will see a hole with a plastic tube in it the bolt is inside this tube and you will need a long socket to get to it....the nuts should be fixed to the sub frame so you dont need to hold them.
Thanx,
job is done, result is excellent.
BTW: I didnt loose the bolt, but the tool... javascript:void(0)
Mad
grtz
amir
