Well I`ve finished putting words to pictures on my recent change of all discs, pads and fluid. I`ve powerpoint slides of approx 1.5 MB and will be happy to submit it to AlfaOwner.com if a moderator can arrange for it to be posted somewhere. If bandwidth is tight then maybe a hosting site will take it?
In a nutshell I replaced the fronts with Black Diamond combi (grooved and drilled) with Ferodo DS2500 pads. The rears are Black Diamond grovved with Ferodo DS Perfomance pads. The fluid was relpaced with dot 5.1. I already had braided hoses.
The whole job cost just over £400 in parts and took about 6 hours. I suppose it could have been done faster but i wasn`t in that much of a hurry.
My brakes weren't that bad before but now are interesting to say the least! Initial braking is standard for the first second or so (until the pad warms up?) but then it gets progressively better and better. It takes a little getting used to as the efficiency improves without you having to press harder on the pedal, but once you get the hang of it and know when to press harder or not this is a seriously good setup for fast road. The car stops amazingly quickly and I often end up stopping way to soon.
Taking people out on roundabaouts just went up to a whole new level
Now if I can just find that coppaslip as one of the pads is squeaking....
