Hi all.. finally the car is getting alive after i changed the crank sensor..
but since the car havent been started for almost i year ill like now to change the spark plugs..
my question is.. are all the plugs with the same size or 2 different?
i have been looked on the site but i get different answers..
also... what is the size of the of the socket wrench i need ?
Robert
Wow that goods! let me know how you get on replacing them. Are you replacing them for a reason or just for general maintenance ?
Mike
i tried to use first a 14 mm socket but it was too little.. so i borrowed a 16 mm
the bigger spark plug "the one connected to the bigger square rubber cap" whent of easy..
"the plus was very wet and black.. so a change of plugs is to be done.."
but now.. the other spark plug.. what size is that?
14 mm was too little and 16 mm too big.. when i see them from above it seems to be the same size..
any idea?
All 8 plugs use the same size socket.
16mm (5/8").
Plugs should be:
4x NGK BKR6EKPA
and
4x NGK PMR7A
