Hi all, can anybody post a link or advise me on purchasing a CF1 3.0 crank sensor for a phase 1 3.0 GTV?
Thanks, Phil
3.0 24v CF1 I think has the crank sensor which reads the toothed wheel on the back of the aux pulley if I remember rightly. Looks that way from ePer page 55101/02. Sensor is apparently part number 46472687 and is readily available to order.
That one in Dirka's link above shows it as also fitting the 156 V6 CF2 and the GTV V6 CF2 etc, so I'm not sure its right.
EDIT: On checking, the GTV V6 CF1 part number is the same as the 156 V6 CF2 part number, and the 156 V6 diagram also shows it as reading the crank pulley wheel and that is definitely NOT the case on the 156 V6, so its probably just a wrong drawing in ePer and the crank sensor instead reads the flywheel and is bolted to the under-side of the sump.
Thanks chaps, I'll get under the car and remove it and see what the part number is, I'll order it from you when I know :)
