Don't know really why, but I've just bought one of the Clarion head units and a CD changer.
I'm trying to work out where the CD changer should be mounted. There's the shelf on the NS in the boot, but I don't think the CD changer should attach to the parcel shelf and can't see anywhere that lines up with the mounting bracket anyway. Anyone have any info, or better still pics?
the unit does fit under the rear parcel shelf to the left as looking from the rear mine used the upper carpet nuts to use doubly as both carpet and cd changer bracket nuts
When I still had mine fitted, it was under the parcel shelf on the right hand side in the boot . Not the best of locations if you have to access the battery though!
Thanks - I've mounted it under the passenger side using the white plastic fixing that hold the boot trim in. I will need to adjust it slightly - the front panel is a bit too tight on the boot top for my fat fingers
