I know this is a frequently asked question.
Just wanted to double check that this was ok to use in a 147, 2.0 selespeed. Until now I have been using selenia 20k. is the selenia 20k a fully synthetic oil or semi? I know both oils are both 10w-40. I'm hoping it wll be fine to mix the two.
There have been mixed views on Magnatec. Some think it drinks more than other oils, but if you are only using it to top-up, you should be OK.
cheers for clearing that up. I always keep an eye on the oil level. Sounds like I may be topping it up even more. Must get the slight oil leak I've got looked at.
