1 - 10 of 10 Posts
THE WIFES ALFA THROWS UP THese codes all the time
could someone please translate them for me? :)
many thanks
Frank
Read diagnostic faultcodes :
Bytes received: 01 6F 00 4B 28
DTC: 0x01 = 1
state : 3
type : 0x0F unknown
condition1 : 0x00
condition2 : 0x4B
counter : 0x28
which ecu?
Engine?
Airbag?
ABS?
what year & engine is the car?
01 Airbag control unit
02 Airbag control unit supply voltage
03 Control light for airbag system
04 Earth connection to control unit housing
05 Display for deactivation of airbag, passenger side
06 Crash Signal
07 Crash Signal
08 Airbag ignition circuit, driver side
09 Airbag ignition circuit, passenger side
0B Seat belt tension ignition circuit, driver side
0C Seat belt tension ignition circuit, passenger side
0E Sidebag ignition circuit, driver side
0F Sidebag ignition circuit, passenger side
12 Resistance seat-occupied sensor, passenger side
14 Keylock switch for disabling passenger airbag
15 Driver side front side impact sensor
17 Passenger side front side impact sensor
19 Cable configuration
1A Warning lamp circuit
21 Ignition circuit, window bag, driver side
22 Ignition circuit, window bag, passenger side
28 Power supply
2F = 47 Rear driver's side airbag explosive charge
34 Passengers Side 1st Stage Head Curtain Airbag Front
KWP71 is used to connect to Airbag & ABS
Unidiag is used to conenct to Engine.
Select com **, & the required m155.def
then press Start = ID
then Diagnose tab
then Read TDC by Status
1 - 10 of 10 Posts
