At my wits end. Today I approached SAC to ask about a Unichip Q4 for my GTV Phase 3. After checking their computer they affirmed that a flag qas raised that they could only provide full load mapping due to ecu limitations. Apparently the Pahse 3 has the ecu which overrides all sensor inputs that a chip or remap might add below 75% throttle input. This means it runs exclusively on measured lamba inputs or will run on calculated results if the system strays from expected returns outside normal parameters.
My question is which other cars share the same ecu as the Phase 3 GTV 3.2?
How are they mapped or chipped?
Should I reconsider asking SAC for help?
I really don't want to fit gotech or the like but would like to optimise my engine beyond the current ecu capabilities.
How do I go about this? :depressed:
